How do I know if my PC has Bluetooth?
2013-07-16T14:42:02+00:00
I have been into Settings and found Wireless, but there is no Bluetooth listed.  Thanks
2013-07-17T06:11:24+00:00
Hi SueLaker,
Thank you for posting your question in Microsoft Community.
Like everything else in your computer, Bluetooth requires both hardware and software. A Bluetooth adapter supplies Bluetooth hardware. If your PC didn’t come with the Bluetooth hardware installed, you can easily add it by purchasing a Bluetooth USB dongle.
. What is the make and model of the computer?
I would suggest you to check the specification of your computer.
To determine whether your PC has Bluetooth hardware, check the Device Manager for Bluetooth Radio by following the steps:
a.    Drag the mouse to bottom left corner and right-click on the ‘Start icon’.
b.    Select ‘Device manager’.
c.    Check for Bluetooth Radio in it or you can also find in Network adapters.
If you need further assistance on this particular issue, let us know and we will be glad to assist you.
1300+ people found this answer helpful.
71 additional answers
    2019-03-11T05:14:54+00:00
    Evidently my 2 year old gaming desktop computer doesn't have Bluetooth. I was trying to use a new xbox Bluetooth controller and headset so my granddaughter could play fortnight and other games. Thanks for any advice. Its an ibuypower computer desktop.
    2019-03-22T05:27:57+00:00
    How to Windose 7 conect  bluetooh
    2019-04-14T01:13:02+00:00
    Hi SueLaker,
    Hello Microsoft-mobile-support team,
    I have the Microsoft Lumia 430 mobile set. Recent I  buy the Rappo S 100 headset. I noticed that it works on pc or android phone but it cannot play on windows phone. The Bluetooth device of windows mobile is not connected to Rappo S 100 headset. Windows mobile is not getting on Bluetooth connection of Rappo S 100.What is the problem here? Please tell me what to do?
    How to data transfer from windows mobile to micro sd memory card? I can not transfer any data from my Windows Mobile.
    Best.
    *** Email address is removed for privacy ***
    2019-05-15T17:38:01+00:00
    I can't find the device manager buton
