2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2016-11-30T03:32:19+00:00
    thx derp when i did this it deactivated the track pad aswell, so i had no mouse and no trackpad.
    however after getting a real mouse i was unable to select no tapping in the track pad and it finally works
