2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2016-11-27T23:34:15+00:00
    Hi Alex,
    Thank you for posting on Microsoft Community Forums.
    I request you to perform the steps and check if it helps.
    a: Press Windows Key +R, type Control Panel.
    b) Select Mouse< Device settings (Under devices there should be your touch pad listed), select it and press the settings button.
    c) Click on the tapping heading to make changes in sensitivity line.
    d) You can adjust sensitivity of your choice.
    Reply to us if you face any issues with disabling Tap  or any other Windows Issue, and we would be glad to assist you.
    Have a nice day!
    Hope this information helps.
    I do not not have a device settings tab
