2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2016-02-26T16:39:46+00:00
    Mine does not say what yours says.  Mine says, "To help prevent the cursor from accidentally moving while you type, change the delay before clicks work."
    Do I need some sort of update?
    Thanks.
