2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-10T02:54:38+00:00
    none of those options are there.  i am also unable to connect to my hidden wireless network, troubleshooter takes you in circles.  i am a very advanced user, with two other professional (A+ certified) web/network designers, we were unable to resolve.  im sending this from my phone because my laptop will not connect. the touchpad is also not troubleshoot-able, there really simply are no settings for it anywhere (tried several drivers from asus, synaptic, and windows...) i really just wish this had come with windows 7.  i enjoyed being able to see things my comp was doing.  i'll be searching for a fix until i finally find one.  or another windows 7 license.
