2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-11-16T21:19:32+00:00
    Vaio control centre>mouse and keyboard>touchpad operations details>uncheck box for tap to click
