2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-08-08T00:13:51+00:00
    Yes, it has been solved.  But that is for the machine models noted in others' solutions.  Mine is an ACER ASPIRE ONE.  Windows 8.1.  Go to Control Panel > Mouse > ELAN tab > Options > Check Enable and then Apply > Uncheck Enable and hit Apply again.
    Unfortunately, I've found myself having to do this every time I turn the machine on.  Most likely an issue with Windows 8.1 compatibility (because it held the setting between off/on prior to the upgrade from Windows 8 to 8.1).
