2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-07-10T22:51:26+00:00
    Using the above information regarding the control panel DOES NOT TAKE YOU TO WHERE YOU CAN DISABLE THE MOUSE CLICK PAD. It only adjust mouse settings.
    Perhaps this is because it is  made and model dependent.
    I have posted elsewhere in this thread where and how to do it.
