2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-07-10T22:46:58+00:00
    to turn off click mouse pad on asus using win 8, right click on arrow next to (battery, volume) etc icons in lower right section of task bar = hidden icons
    double click on the icon that when you mouse over is called Asus smart gesture.
    there you can set different mouse options.
    The last option is MOUSE DETECTION
    Click it, and click in the upper left of that window where it says turn off click pad when mouse is plugged in.
