2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-06-13T18:08:01+00:00
    There is no such option as "Tapping" under mouse tab. It mentions only ASUS touchpad. Working properly. Sick and tired to struggle with typing with this stupid option nobody asked for. Now you even can not disable it!
