2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-03-13T21:21:51+00:00
    search for mouse and even then i dont have the vast options you have listed, only: Buttons, pointers, pointer options and hardware so i dont have the added touch pad option there either
    Try the Hardware tab and see what you have in it.  You might have to do it elevated...
    So, one way to do that (apparently) would be to open an elevated cmd window.  And then in its Administrator: Command Prompt  command line enter:   control.exe  mouse
    Doing that I can then go Properties (button), Driver (tab), and Disable (button).  When I only launch Mouse Properties from Search Settings I do not have the ability to Disable the driver.   YMMV.
    However, please note that this would disable all functions of your Touchpad, so if you don't have touch or a second pointer device to replace it, get that done first.  E.g. at least have Mousekeys available as a standby and be familiar with how to use it.   Hint:  the default keystroke for enabling Mousekeys is pressing and holding LeftAlt+LeftShift+NumLock.
    Good luck
    Robert
