2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-02-19T04:49:48+00:00
    Hi Alex,
    Thank you for posting on Microsoft Community Forums.
    I request you to perform the steps and check if it helps.
    a: Press Windows Key +R, type Control Panel.
    b) Select Mouse< Device settings (Under devices there should be your touch pad listed), select it and press the settings button.
    c) Click on the tapping heading to make changes in sensitivity line.
    d) You can adjust sensitivity of your choice.
    Reply to us if you face any issues with disabling Tap  or any other Windows Issue, and we would be glad to assist you.
    Have a nice day!
    Hope this information helps.
    Why does the Mouse & Touchpad Settings have different options than if accessed via the Control Panel? In PC & Devices I can only change the Touchpad delay. There is plenty of real estate to allow more options. At least there should be a link to the Control Panel's more robust options. I am sure many people navigate to the PC & Devices screen and get very frustrated that they do not have the options they expect that can only be found in the Control Panel mouse options. Why have this limited duplicate screen?
