2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-01-14T01:33:14+00:00
    Look for the Mouse / Touchpad in Control Panel.
    Control Panel > Mouse
    Depending on your version, then look in the Hardware or similar labeled tab.
    Then look under options and/or properties to check if settings are configurable within.
    I had to just open several windows deep until I found mine.  Just cancel out of any windows that you aren't sure of so as to not apply unwanted changes.  Also note any changes you do make in case it turns out you need to revert back.
