2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-01-12T17:22:44+00:00
    I had this same problem, and when I did what you said, my touchpad was not listed under devices, What should I do?
