2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-01-10T18:07:23+00:00
    I have a Toshiba laptop. I went to touchpad driver settings -> search for latest driver, and found that many touchpad settings were disabled. Went to Toshiba.com and downloaded THEIR latest driver, and
    all the good stuff was back in mouse settings.  Just cal me Captain Obvious. Hopefully Win8 and Msoft will improve in time.
