2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-12-25T00:19:19+00:00
    took me a while to find the tapping option on my toshiba. may be the same for you. i have no tapping tab either but have found the way to do it. see if yours is the same. In the mouse settings the top tabs say buttons, pointers, pointer options, wheel, hardware, device settings. i clicked on device settings. it has the option to disable or enable the touchpad and also a settings button.  in that settings menu is a box checked tapping. i un checked it and it sorted it. hopefully you have all these. this is for a synaptics touchpad v7.2
