2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-07-07T16:18:06+00:00
    Alright. We have it figured out. Or at least on mine we do. If you go into Control Panel go into the Device Manager and click on the Mouse. Then click on the tab for Elan (if you have this) and click on Elan smart pad. Then click Options. There is an option there called "tapping." Uncheck the "enable" box and then click Apply. This should do it. It worked for me and I couldn't be happier to not be randomly clicking anymore. Microsoft is relying on a third party manufacturer to develop a driver for the track pad. It may be called something other than Elan on your computer, but it's definitely in the mouse settings.
