2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-06-30T01:26:19+00:00
    I tried a bunch of options and finally found the answer for my laptop.  ACER.  Win8.
    ELAN touchpad.
    Control Panel > Mouse > ELAN tab (far right).  This tab shows "Device:" with your touchpad device listed below.  Left click the device name once.  Then click Options.  Then a separate window opens with all the settings I was looking for.  Hope this helps for you too!
