2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-06-11T04:42:29+00:00
    I found the cure for ASUS users!!!!! PLEASE READ. THIS MAY WORK FOR YOU.
    1. Go to desktop view mode
    2. Click on the up arrow in the bottom right corner
    3. Click on the Smart Gesture button
    4. Under the single touch area, unlike "select"
    5. Click "apply"
    6. BOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOM.
