2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-17T13:27:15+00:00
    Oh, I understand.  I was just trying to help the original poster and any others who might still be struggling to disable the tap to click feature.  Dells' are just called Dell Touchpads.  I always had Synaptics in the past and could easily manipulate it from Control Panel then devices.  I always had HP's, also, not Dell.   I am so glad I finally found the touchpad in hidden icons near the speaker icon.  Ahhhh.  I will keep this laptop now.  Ha ha.
