2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-05-15T19:13:18+00:00
    This is how to do it for those of us who use Synaptics devices: Type Trackpad in the Search Settings charm.  Open the Settings file that has the Synaptic logo on it.  Uncheck the Tapping box and click OK.  The problem should be solved.
