2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-04-23T06:41:48+00:00
    If you go to the Synaptics site ( http://www.synaptics.com/resources/drivers ) and download the first link, you should be able to install the new drivers in Windows 8. Upon a restart, you should get the tray icon.
    This should hopefully work. I just installed Windows 8 and was running into the same issue. This worked for me.
