2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-04-17T21:02:35+00:00
    1. Go to All apps
    2. Click on Control Panel
    3. Search for "Mouse"
    4. Click on "Change Mouse Click Settings"
    5. Click on "Touchpad" tab
    6. Click "Options"
    7. Uncheck Tapping
