2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-02-17T17:19:07+00:00
    I've run into the same problem, all of the typical ways you can do this on other machines & operating systems doesn't work.  I'm checking the Asus tech support, you may want to see if that works for you, too - 1-877-339-2787 (ASUS), http://livesupport.asus.com/chat or http://livesupport.asus.com/email .  Good luck!
