2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-18T19:10:51+00:00
    You're absolutely right... how in God's name could they give you a trackpad without any options for it... I hate tapping more than anything on a computer and I am ready to leave Windows as well...
