2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-11T01:26:32+00:00
    the computer is three days old.  it came with windows 8 installed, and the very first thing i tried to do after setup was disable the tap to click.  i will look into the msinfo32.exe suggestion you have mentioned,  but there are a number of other growing concerns adding up here, first and leastmost the trackpad.  thanks for input! :)
