2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-10T18:27:01+00:00
    windows 8 has disabled my buttons that were hard wired onto my keyboard of this laptop, an ASUS. The button for performance, visuals, and trackpad enable and disable.
    Probably a more realistic way of looking at this is that your keyboard support is now generic instead of customized.   Then you might try looking for the customized keyboard support to be installed instead, in compatibility mode if necessary.    Again, you could use msinfo32.exe to start your checking.   FWIW mine is showing a generic driver but by its description that it is somehow customized by HP.   Then I would suspect that would mean there are some kind of exits being employed which have been added in the registry by the manufacturer's customization software.   (I have gone back to HP, downloaded the W7 keyboard customization and installed it in W8 to make that happen but the actual implementation is my speculation.)   To check out the implementation idea in detail you could compare registry branches in both W7 and W8.
    HTH
    Robert
