2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-10T18:05:48+00:00
    That is too bad, you have gone to the Settings tab under where you type I assume, so I will ask a few more questions if you do not mind.  First: How old is your computer, and is it compatible with Windows 8?  Second: Do you have the Synaptic Touch-pad?  Third: Do you have a third-party anti-virus installed?  That could potentially cause this problem; you may also have a virus.  Scan to see if you have a virus (some change the permissions to files, but do nothing else), and, if you don't mind, try uninstalling the third-party AV you have (if applicable) with the uninstall tool and enabling Windows Defender.  If your computer is compatible with Windows 8, you have a Synaptic Touch-pad and you are using Windows Defender already and do not have a virus, you probably need to reinstall Windows.  I hope you figure something out, and I am sorry for not being of any help to you.
