2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2013-01-10T18:01:22+00:00
    the drivers do not give the user this power
    If you have found the driver you can disable it or uninstall it.   The driver cannot prevent you from doing that.
    Device Manager may not be the best place to start looking if you don't know what you have and if it is hidden under some other uncommon category there.   (IMO Synaptics was a good guess.   I have that too.)    So try using  msinfo32.exe.   E.g. under Components\Input\Pointing Device   I see Hardware Type twice giving product information about both my Touchpad and my Wireless mouse.
    FYI
    Robert
