2013-01-06T19:59:33+00:00
2014-08-26T17:51:47+00:00
There, done.
2013-04-13T14:32:18+00:00
2014-10-25T21:52:00+00:00
2014-09-16T17:02:10+00:00
95 additional answers
    2014-05-10T14:58:51+00:00
    With just a cheap wireless keyboard & trackpad connected in Device Manager under 'Human Interface Device' I have 4 'USB Input Device' entrees with 'HID-Compliant consumer control device' & 'HID-compliant system controller'. The 4 USB Input devices were for 4 discrete features of the device:
    • Keyboard
    • Track pad pointing
    • Trackpad buttons
    • Tap-to-click, two finger scrolling & trackpad edge scrolling
    Disable the correct USB Input device & you disable tap-to-click. If you do this make sure you only disable one device at a time. Also know how to re-enable the devices with your keyboard or have an external mouse incase you disable the pointer or trackpad buttons
