Samsung apps are missing in samsung ativ smart PC Pro
2013-03-10T12:28:36+00:00
Recently I bought samsung ativ smart PC pro from Dubai. For some reason I got blue screen & I had to reset the windows. After restoring windows 8, some of the preinstalled samsung apps are missing from windows store & PC.
I tried below actions, still no solution.
  1. Reinstalled windows 3 times, samsung update also done 3 times
  2. PC given for service, they reinstalled it for 4th time & said its ok. (no improvement)
  3. Contacted S agent online, he remotely tried to check the PC. He said reinstall windows!!!! otherwise contact windows support.
Now I dont know, what windows support is going to direct me to some other company XYZ?
Could some one take the responsibility & resolve the issue, instead of throwing the ball here & there.
Rajesh.
Windows for home | Previous Windows versions | Microsoft Store
    2013-09-25T15:25:21+00:00
    Can you please give the remaining samsung apps link.
    pls help
    2013-11-01T16:05:21+00:00
    File Name : "s note.zip"
    MD5: c01a0abcef77d578a81cba1718985195
    S-Note.part1.rar
    S-Note.part2.rar
    worked for me.
    Samsung ativ smart pc pro + windows 8.1 pro (x64)
    2013-12-23T00:51:32+00:00
    Maybe you should try to upgrade it to windows 8.1 via windows store, it works for me
    2014-05-02T03:14:34+00:00
    Hi Please did you know where can I find the Scamera Apps I change mi SSD for a bigger and then do a fresh install but now I lost all the samsung software I reinstall the Snote thanks to you but still looking for the scamera I cant find any where I have the old backup where it is installed but running Windows 8.1 pro too and I suspect it can have virus, that is why I dont use it to resinstall the system. I found the folder with the cyberlink-Scamera but it dont have any .exe inside so it dont install using the same way snote do.
    Any help please?
    2014-12-06T10:26:45+00:00
    works fine on my Samsung ativ smart pc pro - windows 8.1 pro version 64bit
