hello craig? are you one of the technical support of nokia? i have a lumia 1020. i just updated nokia camera app to v 4.4.08. after this update, it doesn't macro focus on an object. even holding it near 3 inches away on the object. it just doesnt autofocus. even manual focus, it just all blurr. i'm just worried about it. are aware of this problem? i hope its just a bug that can be fixed on the next update. thanks
Lumia 1020 Camera Won't Hold Focus
When using my 1020, I hold the shutter button halfway down to let it autofocus. It proceeds to do so briefly, but as I push the button, it loses focus and results in blurry photos. The manual focus does a little better. If I tap to focus, I can usually get the focus I want after 10 or so tries. This issue comes up at any focal distance.
Is the camera broken?
Thanks.
2013-11-27T14:57:14+00:00 -
2013-11-27T12:50:48+00:00 Hello,
I'm experiencing the same problem. My camera seems to be set to always focus on the farthest setting. Even when I change focus in the manueal setting, nothing happens. Set on the closest manual focus I have perfect focus on things over 100 meters away, and totally blurry in the closest 30 centimetres
2013-11-22T00:25:04+00:00 I had chosen the nokia lumia 1020 as my upgrade phone last month, and i absolutely ADORED the camera on it, but then this same thing started happening to me with the focus...
luckily i was within my 30 days so they sent me another phone.. but apparently this is actually a refurbished one? and now it wont stop freezing! i tried powering it off and it has been frozen for the past 2 hours! anyone having this problem lately?
2013-11-20T12:55:31+00:00 -
2013-11-09T14:57:31+00:00 I have the exact problem with the quick preview was sharp but when I enter the edit, it just turns blurry. Worst thing is my battery life, the phone just couldn't last for more than 10 hours with minimal usage. I'm so frustrated with always want to monitoring on the battery percentage. Very very disappointed with this 1020. I switch from android and get bad experience. :(
