I did a screen print, and copied it to a text document, and printed it that way. I agree with Bigpapa, MS is still trying to shove IE down people's throats. Shivam is just toeing the company line.
how can i fix error code 2147500037
Original Title:
Network Programs Network Networking Internet Website Web Site URL Web Site
2015-05-30T13:10:38+00:00 -
2015-05-30T15:15:38+00:00 Hello,
Thank you for the Update on related issue.
If OP (original post) writer would not reply with the details then how can we reach the conclusion. Please do not blame Microsoft or Internet Explorer unnecessarily and without any research. What you thinking is just an assumption. We certainly like if our valuable users use our programs but it bring no good to our program by enforcing users to uninstall third party program.
Please think other way around, Internet Explorer and Windows shares system files and if would be obvious if Windows need Internet Explorer active during course of troubleshooting.
Please feel free to reply, in case you face any other issues with Windows in future.
Shivam,
The research you claim I should do really falls on MS to perform. I've given you the problem, now it's up to you(MS) to find the solution. And, any good engineer should know how to perform Analytical Problem Solving to determine what IS and IS NOT the problem.
Problem: User cannot print Homegroup password using a browser other than IE as their default browser.
Now as part of YOUR(MS) research you need to perform the following (not all inclusive) tasks.
- Install Firefox
- Make it your DEFAULT browser
- Attempt to print Homegroup password
- Diagnose the problem
- Correct the problem
- Repeat Steps 1-5 for Chrome, Firefox Nightly (64bit), SeaMonkey, Safari, Opera, ...
Since you and only you have access to the source code, YOU(MS) must accept responsibility to correct this problem.
There may be workarounds, like the previous post but, that's all they are, workarounds, not a solution.
2015-05-30T15:26:46+00:00 Does this help?
You may receive error "2147500037" when you start the Message Queuing Triggers service
2015-05-30T19:15:41+00:00 Thanks but, I'm not doing development or Message Queuing - unless MS does it by default when trying to place the "Print HomeGroup" report in the printer queue.
The account I'm logged into is a member of the Administrators Group so there should be no issues with permissions, although I'm not 100% sure MS acknowledges that membership as I've had to "Run as Administrator" on the install package of many of the apps I've installed to get it installed correctly.
I do not have MQExplorer installed nor do I want to pay for it to test to see if MQseries is the potential fix - Sorry, MQseries is the OpenVMS equivalence to IBM's MQExplorer.
OS Name Microsoft Windows 7 Professional
Version 6.1.7601 Service Pack 1 Build 7601
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name MDSBIGPAPA-PC
System Manufacturer Hewlett-Packard
System Model HP EliteOne 800 G1 AiO
System Type x64-based PC
Processor Intel(R) Core(TM) i5-4570S CPU @ 2.90GHz, 2901 Mhz, 4 Core(s), 4 Logical Processor(s)
BIOS Version/Date Hewlett-Packard L01 v02.59, 2015-03-16
SMBIOS Version 2.7
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United States
Hardware Abstraction Layer Version = "6.1.7601.17514"
User Name MDSBigPaPa-PC\MDSBigPaPa
2015-06-13T15:22:44+00:00 Hi,
Thanks for your continues response. I appreciate your efforts in resolving the issue.
You can check the resolution provided by Afzal Taher on March 8, 2010, the answer was helpful.
Please post back with the results. We will be glad to assist you further.
____________________
Thanks & Regards,
Isha Soni
