I don't know if anyone else has posted this as a reply, as there are 130 responses and I don't feel like leafing through each one. From what I can see, the general consensus is that you must set IE as your default browser, then Control Panel, then Homegroup,
and then click on the option to see/print your password. Print it. Then, (again, according to what I see in some of the responses) you change your default browser back to whatever you prefer (IMHO ANYTHING but IE!!)
I, too, couldn't print my Homegroup password. I use Firefox - have been for years, not changing. This is what I did:
Before doing anything, log off of, and turn off, all other computers in your network.
Click on the Window, lower left corner.
Click Control Panel
Click Homegroup
Run Homegroup troubleshooter.
When Troubleshooter is done, close it out. At this point, you should be presented with the option to start a New Homegroup.
Do so.
Again, you will not be able to print the password that you will be given because you are not (I hope) using IE. You can, however...
- Write your new password down. I recommend that you do so. Then, leaving the password page open,
- Click the Window, lower left corner.
- Type the word "snip" which will give you a "Snipping Tool". Click "NEW" in the upper left corner of the Snip Tool.
- Everything on the page will "gray out". Place the pointer at the upper left corner of what you want to print, click and hold, outline what you want to print, release the click you were holding... click on "File", click on "Print"... print away! Long,
but effective.
