Sadly no. Sometimes there'd still be sound after sleep mode if I open a .mkv file in VLC player before playing anything else, but I'm sure that's more of a coincidence. It doesn't help if I'm in the middle of listening to something and I get a notification that my headphones were unplugged from the audio jack (though I didn't unplug them), which is a sign that my sound has gone again and no other way to restore it besides restarting the computer. It's a pretty unpredictable problem and it just happens whenever for no special reason, it's so annoying.
Need to restart my laptop every time to get sound.
Original title: Problems With Windows 8 Sound
Hi ,
I got a problem with Sound in Windows 8 Operating System (hP G60 model)..Device drivers are installed properly ..!! I need to restart my laptop every time problem occurs..if i restart the laptop, sound is working fine..!!..I have no idea why its not coming sound when i first switch on laptop.!every time i need to restart laptop for sound.! one more problem is if i haven't used laptop for 15-20min it goes sleeping mode and when i used back - again facing same problem.!!..Does i need to install any drivers?..Does it require?..Plz help me out..Thank your for your help in advance.!!
2014-07-27T15:36:29+00:00 -
2014-07-30T00:31:51+00:00 THANK YOU! This works for me too...annoying yes, but like you said, much better than restarting all the time!
2014-07-30T00:33:41+00:00 I also have this problem with an Asus laptop with Conexant SmartAudio HD, similar to hpkathy's post.
The only "fix" - which is TEMPORARY - is to scan hardware.
WHERE IS MICROSOFT ON ADDRESSING THIS ISSUE?
My thoughts exactly. It's clearly a widespread problem. I had this happen a year or so ago with an update and they sent a patch out or something in a few days....its been weeks....almost makes me want to go Apple...just saying...
2014-07-30T15:39:20+00:00 scan hardware doesnt't work for me. This is annoying. MS should be concerned about losing the userbase instead of igoring user's issues like this.
2014-07-30T17:11:56+00:00 My problem doesn't occur any more after sleep mode if I immediately play something in VLC player. However, it can happen any time later, I use headphones a lot when I get a notification that they've been unplugged from the audio jack, that's when I know the sound died again and that can happen like every 5 minutes. As a temporary fix only restarting helped, but now ''scan for hardware changes'' helps too, though it didn't before. Go figure.
