Need to restart my laptop every time to get sound.
2013-03-20T19:44:28+00:00
Original title: Problems With Windows 8 Sound
Hi ,
     I got a problem with Sound in Windows 8 Operating System (hP G60 model)..Device drivers are installed properly ..!! I need to restart my laptop every time problem occurs..if i restart the laptop,  sound is working fine..!!..I have no idea why its not coming sound when i first switch on laptop.!every time i need to restart laptop for sound.! one more problem is if i haven't used laptop for 15-20min it goes sleeping  mode and  when i  used back - again facing same problem.!!..Does i need to install any drivers?..Does it require?..Plz help me out..Thank your for your help in advance.!!
    2014-07-19T23:30:10+00:00
    I had the same issue since the windows update. I solve it but putting back the last version of my audio pilote in control panel. Hope it will help! :)
    2014-07-20T17:44:49+00:00
    [SOLVED!]
    I was able to solve this problem by switching operating systems (GNU/Linux Distribution). (obviously)
    It's a really fun process and quite technologically invigorating to make the big switch from windows to GNU/linux.
    2014-07-21T02:58:59+00:00
    I HAVE THE SAME PROBLEM WITH MY SAMSUNG LAPTOP, EVEN THINK ON A VIRUS, DID YOU HAD ANY SOLUTION FOR THIS ?
    2014-07-21T17:52:23+00:00
    I also have this problem with an Asus laptop with Conexant SmartAudio HD, similar to hpkathy's post.
    The only "fix" - which is TEMPORARY - is to scan hardware.
    WHERE IS MICROSOFT ON ADDRESSING THIS ISSUE?
    2014-07-21T17:57:17+00:00
    There is another troubleshooting tutorial here:
    http://answers.microsoft.com/en-us/windows/forum/windows8\_1-hardware/no-sound-in-windows-81/545bfd03-2603-43f2-b800-224784aa6a86
    This has not worked for me.  If anyone has luck with this, please let us know.
    Thank you.
