How to solve, "Reboot and Select proper Boot device"
2012-12-10T10:13:32+00:00
This keeps showing up when I turn on my computer and I cannot resume.
"Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key"
This shows up again after I press a key.
This happened when I connected the master plug part of the ATA Cable to my hard disk because I saw that it was connected to the slave part of the ATA Cable. I din't meddle with the jump block because I didn't know what to do to this.
When I open my computer I saw this problem.
I connected back the slave part of the ATA of my hard disk to see if I undo the problem but when I open my computer, still this problem shows up.
What can I do. My HDD is Hitachi, 80GB, 7200RPM and this is only one HDD in my computer.
I also have a question.
What is a Slave and a Master Drive?
What's their difference?
2012-12-11T04:58:58+00:00
Hi Sora,
Thank you for posting your question in the Microsoft community.
I understand that whenever you start the computer you see the message “"Reboot and Select proper Boot device or Insert Boot Media in selected Boot device and press a key"
Usually this error message occurs if in the BIOS, booting is set as to start from CD Rom or floppy drive as first boot device. Where as you are trying to boot from the Hard disk.
Go into BIOS  and change the Drive Boot Order so that the Hard Drive comes first as a boot priority. You should be able to boot into Windows normally after you save it to that configuration.
Note: Modifying BIOS/complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
For help with the BIOS settings, refer to the computer manual or contact the manufacturer.
2015-05-22T14:23:19+00:00
Hello Alan,
Thank you for the reply.
I appreciate your patience.
I hope that you tried to follow suggestion provided in the previous post.
If it does not help, I would suggest you to contact your motherboard's manufacturer for further assistance.
ECS support
http://www.ecs.com.tw/ECSWebSite/Support/technical_Support_List.aspx?MenuID=50&LanID=0
Thank you
51 additional answers
    2017-08-07T15:42:46+00:00
    How do i go into BIOS when i can't get past "Reboot and Select proper Boot device or Insert Boot Media in selected boot device and press any key."
    2017-09-25T12:05:17+00:00
    kill me
    2017-11-24T22:40:19+00:00
    What is BIOS, how do I get into it, and where, and how do I make this change? How do I get a Boot Disk? How do I get the computer to boot properly when it's constantly asking for this disk? How to I PERMANENTLY DISABLE Energy Star? This is what's causing my computer to crash constantly, and why it won't re-boot. Please COPY MY EMAIL on your response, because I don't know how to find this page again - ******@aol.com - Thank you.
