usb flash drive not a valid backup location for system image
2013-08-14T13:07:06+00:00
OK, Microsoft continuing to confuse me and others it would seem.
Tried to make system image to USB flash drive in Windows 8 and Yes it would not work. It States " the drive is not a valid backup location ".
Yes its formatted to NTFS. and I have read various sites where it gives instructions how and ive read sites and Microsoft who seem to have conflicting statements.
Please can someone HELP all I want to do is go to windows 7 file recovery in windows 8 - press make system image - select usb drive and sit back.
Windows for home | Other | Recovery and backup
    2013-08-28T06:38:31+00:00
    Thanks for reply , will get back when attempted and succeeded or failed.
    Regards.
    shivj
    2013-08-28T07:04:21+00:00
    Tried and this is response from command prompt :-
    The recovery image cannot be written
    Error code 0x8007010b
    2013-08-28T07:18:03+00:00
    the correct line is "createimage" and when entered correct line warnings appeared and stated that creating a custom image can only be used on Refresh not Reset .
    Regards
    Shivj
    2013-12-19T13:12:24+00:00
    I appreciate your reply but I have 64gb flash drive and my system image is only approx. 16gb ,as I knew before getting that size flash drive.
    Is it possible to place the flash drive as part of home network and then proceed to backup to that location.
    Hi there!
    I have Windows 7 freshly installed on my machine and I decided to install all the program that I need,
    then create a system image.
    I bought the same type of USB stick, but from different supplier...the 2 of 64GB and 1 of 128GB.
    The System image at the point I attempt to create is DECLARED from Windows 42GB.
    I format the 64GB USB stick prior attempting creating the image with Windows,
    and Windows does not recognize this a valid device(corrupt message).
    I was very frustrated then I tried to use the 128 GB. Same process...
    Windows recognize them as proper and created the image.
    However at this point I wanted also tried to use it.
    Separate, I created a DVD for the startup that work correctly.
    At the point of RESTORiNG the image from USB, Windows cannot recognize the USB connected to the machine as lack of drivers.
    Then I used the Dos prompt to install the driver...I made prior two different DVD...1DVD with the exact .inf .dll  than WiN7 is using when running, 1 with setup file from internet executable to install the driver.
    Both ways has been a failure...no probs now...but when recover image will be necessary what I will do?
    Been trough the old MSCDEX cd driver and SATA driver dedicated installation by myself...here a new problem harder then previous
    It is possible that with weekly update Microsoft cannot sort this so simple things in 2013?
    Technically a HARD DRiVE is not safer than USB pen properly stored
    DIRECT QUESTiON: How to install the usb driver installed to recover system image ?
    2014-01-26T15:32:45+00:00
    Try this:
    • create a directory on your USB drive
    • right-click the directory and choose "Share with", "Specific people"
    • choose yourself from the list of users and click Share and Done
    • in the "Create System Image" menu choose "On a network location"
    • now enter the URL for your share (\your-computer\sharename)
    • enter your username and password and click OK
    Good luck.
    /Claus
