Lumia 820 Wi-Fi WILL NOT CONNECT AT ALL
2013-03-16T13:10:45+00:00
I've recently bought the "new Nokia Lumia 820 with Windows Phone", and it just won't connect to my wi-fi network at home. Let me tell you that I love this phone, but this issue is totally unacceptable since my 3G plan will not last forever. The WiFi works in my friend's house and few other places, but it JUST WON'T CONNECT in my house. What I HAVE tried is,
  • almost all combinations of wifi settings
  • resetting the phone (but not to a fresh reset; I only used my backup)
  • many attempts to connect
  • taking it to the care centre, where they told me that the phone is fine and also managed to connect it to their WiFi and made me look like a **bleep**
  • connecting other devices like my brother's Galaxy S2 (which connects IMMEDIATELY) and my laptop (which also connects easily)
  • different (and simpler) SSIDs and passwords
  • restarting the phone/wifi option and then trying again
  • updating the router's firmware
  • check the hidden networks tab and try to add it as a hidden network
  • reset the router to factory settings
I don't know what the Windows Phone OS does when it tries to connect to my network, but this is the error it gives me:
"Connection unsuccessful.
Your phone couldn't connect to the WiFi network ***** because there was no response from the network. Please try again later."
-OR-
Unnecessarily gives me a password incorrect message and then:
"Your phone couldn't reach the WiFi network ****".
My router model is DLink DSL-2750U and these are my WiFi settings on it:
Basic:
Hide Access Point: OFF
Client Isolation: OFF
SSID isolation: OFF
Country: INDIA
Max. Clients: 16
Security:
Enable WPS: OFF
Network Authentication: WPA-Personal
out of Auto, WAP2 only and WPA only, I've selected Auto
WPA/WAPI Encryption: TPIK+AES
WPA Group Rekey Interval:0
MAC Filter:
I've added my phone's MAC address correctly and set the filter to allow; no luck.
Advanced:
there are a lot of settings under this, and the problem still persists even on the defaults.
I've set the channel to "Auto" out of 1-9.
Standard Mode is 802.11ng. It still gives me the error if I select 802.11b/g.
Bandwidth is on 20MHz. The Auto option in this doesn't help.
Station Info:
In this, I can see my phones MAC address, but for some reason the associated column is left blank.
MAC
Associated
SSID
Interface
wl0
That's it. I don't want to be replacing my phone as it's only been a month since I bought it.
Please, oh please, come up with a solution and THANK YOU for reading!!
2013-04-22T12:04:51+00:00
Hi ChristianBrein
Thank you for posting and welcome to Nokia Support Discussions! :Cool:
If you face such issue, try the following:
1.  Move closer to a WLAN access point to get a better WLAN signal.
2.  If possible, try to create a connection with some other device that supports WLAN (to see that access point is really working).
3.  Restart/reset the WLAN access point, and try to create a connection again.
4.  If some manufacturer specific network mode (Turbo/Nitro/Super/Afterburner/108/SRX) is used, disable it and try the basic modes 802.11b/g/n.
5.  Check that DHCP (dynamic host configuration protocol) is activated in the WLAN access point.
6.  Set the WLAN access point to SSID visible mode (at least temporarily) to check that the Lumia phone finds your WLAN access point properly, and to prevent SSID typing mistakes.
7.  On the router, remove the WLAN security settings temporarily, and try to create a WLAN connection from the phone without any security settings first. WPA2 (AES) is currently the strongest form of security offered by WiFi products, and is recommended for all uses, choose WPA2 with AES (do not use TKIP).
  • If you have older WiFi devices on your network that do not support WPA2 Personal (AES), select WPA/WPA2 Mixed Mode. This mode will allow newer devices to use the stronger WPA2 AES encryption, while still allowing older devices to connect with older WPA TKIP encryption.
  • If your WiFi router doesn't support WPA/WPA2 Mixed Mode, then WEP128 with Shared Authentication should be used (with a single WEP key in key index 1).
8.  Check that you do not have MAC (Media Access Control) address filtering on in the access point settings. If your WLAN network uses MAC address filtering for security, you will need to know the MAC address for your phone, and then add it to the access list for that network before you can connect. To find the MAC address for your phone, do the following:
  1. Press Start, then swipe left to the App list.
  2. Select Settings > About > More Info.
  3. Then note the MAC address.
9.  If there are many WLAN access points nearby, try to use a different wireless channel in your WLAN access point. Select channel 1, 6, or 11 to optimize wireless performance.
  1. Check if there is a software update available for your WLAN router.
  2. If you are using a public WLAN access point, it is possible that all IP addresses are in use. Try to create a connection again later.
12. On your Lumia phone, delete non functioning WLAN access point (internet connection) and connect it again:
  1. Disconnect the WLAN connection if connected.
  2. Press Start, then swipe left to the App list.
  3. Select Settings > WiFi.
  4. Press Advanced at the bottom of the screen.
  5. Tap and hold on the access point name and select Delete.
  6. Now add the access point again.
  7. On the Advanced screen, tap Add , type the network name in the Network name box, and then tap Add.
  8. On the Sign in screen, type the password in the Password box, and then tap Done.
  9. Tap the Back key once finished.
43 additional answers
    2013-08-01T17:53:22+00:00
    Same problem here... Got home Lumia 920 will not connect to dlink. But used to and very well. Ssid and all pwd details are correct 3ft from router but phone says could not connect to wireles ***. Before anyone responds please be aware I am a IT manager with 25 years experience and have tried everything. What is wrong with win8 on this phone...
    2013-08-01T19:00:12+00:00
    Your Nokia Lumia 920 and your D-Link worked in the past together, correct?
    Which D-Link model is that exactly?
    2013-08-07T14:52:57+00:00
    I face the same issue for the NOKIA LUMIA 925. The error resolved after i disable the auto assign chennel, fix assign it to 6 (D-LINK Router DIR615). The wifi appear at the searching list. follow -> 9.  If there are many WLAN access points nearby, try to use a different wireless channel in your WLAN access point. Select channel 1, 6, or 11 to optimize wireless performance. Thanks.
    2013-09-04T07:25:52+00:00
    I had the same problem with the Lumia 920. The solution for me was:
    1. to delete the IP reservation in the DLink Router using the admin pannel
    2. On the Phone delete the saved login details for the Dlink access point. (click advanced in the wifi settings on the phone and then find the Known network, Locate your dlink network that was saved, hold it until you get the delete option and press delete) Then reselect the network and renter the passowrd.
    hope it works for you ;)
