So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
thanks jack you savednmy lumia 620 so grateful to you....thanks
Thank you Jack! !
I turned my phone off to get on a plane and when we landed and I turned it back on I got the bolt and gear! I totally panicked! But your instructions worked like a charm.
Suzy
