lighting bolt and gear icon
2013-03-31T15:13:28+00:00
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
2013-03-31T15:15:27+00:00
So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
2013-07-24T07:21:07+00:00
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
165 additional answers
    2017-12-28T04:07:58+00:00
    I fixed it by using a small screwdriver, and clicking he reset button at the bottom of the headphone jack port... That fixed it.
    Ultimately, though... I ended up going to an Android.  Sad that Microsoft turned its back on WindowsPhone... it had so much potential!
    2017-12-28T12:58:01+00:00
    On my side, I will wait 2019 to end up going to Google :-( or the new flavor from Microsoft :-)
    Microsoft turned its back because market turned its back (consumers and app providers)
    2018-03-30T17:33:43+00:00
    thank you! you saved me from wanting to throw my phone against a wall.
