lighting bolt and gear icon
2013-03-31T15:13:28+00:00
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
2013-03-31T15:15:27+00:00
So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
2013-07-24T07:21:07+00:00
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
165 additional answers
    2016-01-26T14:24:04+00:00
    My issue and a big one is for a while battery was **** took 8hrs or more for a full charge.. dying within 2.. Had 50gb or more of photos and date. but was unable to transfer needed windows 8 didtn have it nor the room to ack up. should have got some sdcards n asked in store.. but it came on died within 30 seconds of coming on did twice then was a blue screen when I left it over night.. Been told its software issue but unlikely I can get it working without losing all my photos and they are worth more to be than the poxy phone.. is there anyway???.. I haven't backedup elsewhere
    2016-02-06T18:17:53+00:00
    worked perfectly!  Thanks!
    2016-02-09T19:31:46+00:00
    I know have an Sony Xperia Z5 which does not have the problems.
    Thanks for your assistance.
