lighting bolt and gear icon
2013-03-31T15:13:28+00:00
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
2013-03-31T15:15:27+00:00
So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
2013-07-24T07:21:07+00:00
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
165 additional answers
    2015-01-04T14:12:01+00:00
    Just take the batery out and then put it back in again, worked for me with my nokia lumia 520
    2015-01-09T05:38:35+00:00
    Hey jack I've tried n tried n tried still no success with your instructions keeps taking me back to the charge symbol
    idk what else to do
    2015-01-09T13:00:36+00:00
    idk what else to do
    Do you mean the big icon showing a battery?
