lighting bolt and gear icon
2013-03-31T15:13:28+00:00
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
2013-03-31T15:15:27+00:00
So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
2013-07-24T07:21:07+00:00
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
165 additional answers
    2014-06-13T18:34:24+00:00
    thank you, this seems to have worked for my phone
    2014-06-18T19:47:28+00:00
    You are a genius!  Talking during a thunderstorm and all of the sudden my phone went to black with a bolt and gear.  I pressed the said buttons and within minutes it was back on and working.  THANK YOU THANK YOU.
    Andie
    2014-06-19T13:55:11+00:00
    Thanks to all, resolved.
