So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
Hi Jack. I've tried sooo many steps. It's been 5 hours since my last try. Still stuck in spinning gear screen. I have my adapter plugged on and connected to my phone, but still won't stop. Been looking anywhere to find the answer for this problem.
So I want you to read this wiki article:
Reset operation stuck on spinning gears - Solution
This Worked For Me
