So lets try this and see if it helps.
Hard Reset using buttons:
Press and hold the Camera + Volume Down + Power until the phone vibrates. Then release the Power key and keep pressing the Camera + Volume Down for a few seconds.
My Nokia Lumia 920 shows the lightning bolt and gear icon. does not start and is frozen on that icon.
A HAD SAME PROBLEM TOOK OUT MEMORY CARD ATTACHED TO LAPTOP AND PRESSED VOLUME <DOWN> AND POWER BUTTON AND IT CAME ON
I did what you said and it's not working for me ... what to do next ? ... thanks
life saver!!! just replaced my digitizer and had this same problem.. I tried your suggestion and it worked. plus i learned a new trick as before this hard reset i had only ever known how to do a soft reset with just power and volume down until it vibrates.
thank you!!
i spoke too soon, now i also am experiencing this same problem.
