Unknown USB Device (Port Reset Failed)
2013-05-16T04:28:04+00:00
Windows has stopped this device because it has reported problems. (Code 43)
Driver Version 6.2.9200.16384
Location Port_#0002.Hub_#0004
Universal Serial Bus controllers
(Standard USB Host Controller)
Anyone know a way to fix this?
Btw I tried troubleshooting it and it didn't help.
2013-05-16T20:29:47+00:00
Hi Billy,
Did you make any changes to the computer prior to the issue?
Windows has stopped this device because it has reported problems. (Code 43) Let is try the following steps.
Method 1:
Open the Hardware and Devices troubleshooter by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering hardware and devices in the search box, tapping or clicking Settings, and then tapping or clicking Find and fix problems with devices.‌  You might be asked for an admin password or to confirm your choice.
Method 2: Remove and reinstall all USB controllers. Follow these steps:
a)    Press Windows + R, type devmgmt.msc in the run box box and press OK.
b)    Expand Universal Serial Bus controllers.
c)    Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
d)    Restart the computer, and then reinstall the USB controllers.
e)    Plug in the removable USB device, and then test to make sure that the issue is resolved.
Post us the results once you try the above steps.
43 additional answers
    2016-05-17T10:53:21+00:00
    not working, usb ports still not working
    ******@hotmail.com
    2016-07-15T12:32:58+00:00
    I have done this numerous times and the next day it is back again.  I need a permanent solution.  I am starting to think upgrading my Toshiba Satellite A355 to Windows 10 based on continual pop-up requests from Microsoft was not a good idea.
    2016-08-08T19:34:04+00:00
    how do you reinstall the usb controlls
    2016-08-09T00:33:27+00:00
    The USBs reinstall automatically when your device boots up
