Unknown USB Device (Port Reset Failed)
2013-05-16T04:28:04+00:00
Windows has stopped this device because it has reported problems. (Code 43)
Driver Version 6.2.9200.16384
Location Port_#0002.Hub_#0004
Universal Serial Bus controllers
(Standard USB Host Controller)
Anyone know a way to fix this?
Btw I tried troubleshooting it and it didn't help.
2013-05-16T20:29:47+00:00
Hi Billy,
Did you make any changes to the computer prior to the issue?
Windows has stopped this device because it has reported problems. (Code 43) Let is try the following steps.
Method 1:
Open the Hardware and Devices troubleshooter by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering hardware and devices in the search box, tapping or clicking Settings, and then tapping or clicking Find and fix problems with devices.‌  You might be asked for an admin password or to confirm your choice.
Method 2: Remove and reinstall all USB controllers. Follow these steps:
a)    Press Windows + R, type devmgmt.msc in the run box box and press OK.
b)    Expand Universal Serial Bus controllers.
c)    Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
d)    Restart the computer, and then reinstall the USB controllers.
e)    Plug in the removable USB device, and then test to make sure that the issue is resolved.
Post us the results once you try the above steps.
43 additional answers
    2015-10-29T15:53:25+00:00
    Nothin changed. Ports are still dead. my usb mouse , bluetooth and many others not getting recognized. In device manager it shows the same thing " PORT RESET FAILED "
    2015-12-18T14:30:17+00:00
    this isnt working
    2016-03-26T14:50:35+00:00
    I am also facing the same problem, I tried uninstalling it and restarting my laptop but it didn't help.I use the external mouse for gaming and now it is getting difficult to play and I got used to that mouse,please tell if there is any other method for this
    2016-03-26T14:52:11+00:00
    All MY USB ports are dead and nothing gets detected
