Unknown USB Device (Port Reset Failed)
2013-05-16T04:28:04+00:00
Windows has stopped this device because it has reported problems. (Code 43)
Driver Version 6.2.9200.16384
Location Port_#0002.Hub_#0004
Universal Serial Bus controllers
(Standard USB Host Controller)
Anyone know a way to fix this?
Btw I tried troubleshooting it and it didn't help.
2013-05-16T20:29:47+00:00
Hi Billy,
Did you make any changes to the computer prior to the issue?
Windows has stopped this device because it has reported problems. (Code 43) Let is try the following steps.
Method 1:
Open the Hardware and Devices troubleshooter by swiping in from the right edge of the screen, tapping Search (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking Search), entering hardware and devices in the search box, tapping or clicking Settings, and then tapping or clicking Find and fix problems with devices.‌  You might be asked for an admin password or to confirm your choice.
Method 2: Remove and reinstall all USB controllers. Follow these steps:
a)    Press Windows + R, type devmgmt.msc in the run box box and press OK.
b)    Expand Universal Serial Bus controllers.
c)    Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
d)    Restart the computer, and then reinstall the USB controllers.
e)    Plug in the removable USB device, and then test to make sure that the issue is resolved.
Post us the results once you try the above steps.
43 additional answers
    2014-07-09T19:46:11+00:00
    I reinstalled windows 8.1 and everything worked perfect after that at USB 3 speeds.
    2015-01-20T15:57:17+00:00
    THANK YOU!!! Saved my life, thought my backup drive was broken!
    2015-02-21T00:19:39+00:00
    I get this on both of my laptops when trying to connect my iPhone.. I haven't tried anything else.. none of the fixes have worked and beyond frustrating... Why wont you fix this Microsoft?
    2015-03-10T22:09:38+00:00
    i did this. now none of them work
