How safe is RegCure Pro?
2013-03-13T14:49:26+00:00
Should I allow RegCure PRO from Pareto Logic make changes on my pc?
2013-03-14T00:35:23+00:00
No! You should dump it immediately. Don't run it and don't let it do
anything.
Registry cleaning programs are all snake oil. Cleaning of the
registry isn't needed and is dangerous. Leave the registry alone and
don't use any registry cleaner. Despite what many people think, and
what vendors of registry cleaning software try to convince you of,
having unused registry entries doesn't really hurt you.
The risk of a serious problem caused by a registry cleaner erroneously
removing an entry you need is far greater than any potential benefit
it may have.
Read http://www.edbott.com/weblog/archives/000643.html
and http://aumha.net/viewtopic.php?t=28099
and also
http://blogs.technet.com/markrussinovich/archive/2005/10/02/registry-junk-a-windows-fact-of-life.aspx
Let me point out that neither I nor anyone else who warns against the
use of registry cleaners has ever said that they always cause
problems. If they always caused problems, they would disappear from
the market almost immediately. Many people have used a registry
cleaner and never had a problem with it.
Rather, the problem with a registry cleaner is that it carries with it
the substantial risk of having a problem. And since there is no
benefit to using a registry cleaner, running that risk is a very bad
bargain.
2013-03-13T17:28:09+00:00
As with all these 'SpeedUpMyPc' type of programs as safe as holding a rattle snake by its tail
120 additional answers
    2015-03-16T19:27:20+00:00
    On Mon, 16 Mar 2015 17:23:11 +0000, Hilary.S wrote:
    I am also a happy RegCure customer. My job demands that I look at a lot of spammy website and am constantly getting search hijackers and registry errors. After installing RegCure Pro 2 years ago, I haven't had any of the same problems I had when only using Windows Defender and Norton.  I cancelled Norton but kept RegCure Pro.  I have no complaints.
    Your choice of course, but let me point out that neither I nor anyone
    else who warns against the use of registry cleaners has ever said that
    they always cause problems. If they always caused problems, they would
    disappear from the market almost immediately. Many people have used a
    registry cleaner and never had a problem with it.
    bargain.
    2015-03-16T20:51:03+00:00
    I have been following this thread since I posted concerns about **** about 18 mnths ago. I happened to run a free malware scan with HitmanPro by SurfRight yesterday as a one off 'second opinion' scan. It revealed remnants of **** and Systweak still embedded in my PC. No other scan has done so. Unfortunately , as I had previously used up a trial sub I had to pay for a years sub. $16.00 to get them removed. Worth it though just to finally, I hope, see the last of ****.
    2015-03-27T06:57:13+00:00
    If regclean pro is so bad then how come most PC Repair places use it and recommend it.  I have a windows 7 which is acting up running slow and have runtime errors with Microsoft works 8 program which before the trouble started was working great . then after a windows update blame IE stopped working and was giving that windows shutting down due to error message  but I got it fixed then not only found out that Microsoft works 8 would no longer work even after I uninstalled and reinstalled it. but now it triggers the user account control settings. and every know and again the computer freezes, IE windows shut down and restarts, fickers and something windows itself restarts, the screen flickers the start menu button goes completely white then then starts working again. I done all the disk fragmentation, disk cleanup, everything except use a pc cleaner/registry cleaner/fix software. No I don't have a backup for my 2 tb harddrive. I was told by a local computer repair place to use regclean pro. every scan for registry errors from at least 10 different registry/ pc cleaning software programs  I have gotten  exact same over 540 registry errors.  Could it simply be Microsoft wants people to buy more computers and their software and not repair it so their computers last for ages. I have a XP computer my first that I bought from office depot in 2005 a Compaq 150gig . and it still runs. it needs registry cleaned and cleaned up and its slow but it still works. but my current computer has started screwing up this January . the problem is that during the windows update it erased the restore point and created a new one. so I couldn't have went back if I wanted to.  So your telling the only safest thing to do is buy a external hard drive back up my files then do a complete systems restore the way was when it came out of the factory.  instead of any of these registry cleaners. then way is there no public announcements on tv about these things not working or being dangerous to your computer. Because that should be out there and why is not the BBB going after these companies for fraudulent advertising if their product does do as it said. hell the BBB and the FDA went after cheerios for having lowers cholesterol on the box.  so this is even worse.  Right now I am back on the fence I was gonna I am gonna go get me information from other local pc repair shops before I buy it. but I am not buying that registry doesnt need repaired and cleaned and there is not a current safe one out there that actually works.
